Removed lower plugs and top dsicant plugs from engine. Lubricated cylinders with engine oil preservative and rotated crankshaft for #1 cylinder top dead center. Cleaned prop flange base plate and coated prop studs with oil. Mounted flywheel aonto prop flange. Riveted spinner plate doubler and flange. Removed nuts from prop for spinner back plate attachment.
