Brief Description: Heat exchanger and alternate air
Installed SCEET tubing from baffle port to heat exchanger. Manufactured filtered airbox fuel servo gasket from cork-rubber sheet. Installed filtered airbox to fuel servo and safety wired bolts. Drilled #30 drain hole at lowest section of FAB. Cut CT A-740 alternate air casing and cable. Installed alternate air door and checked for operation.
