Karl Richcreek's RV8 Web Site
Date:  4-2-2014
Number of Hours:  2.70
Brief Description:  Exhaust system
Removed heat muff, exhaust support brackets and all four exhaust pipes.
Safety wired clamp on #4 intake port for oil hose.
Drilled all 4 exhaust EGT temperature probe locations at 2 inches from edge of flanges.
Had to remove outboard #4 exhaust stud due to not enough threads. Damaged during removal.
Installed #1 and #3 exhaust pipes.
Installed #1 and #3 EGT probes.
Cleaned and painted exhaust supports with high temperature paint.
Removed and painted throttle bracket.
