Torqued upper spark plug inserts to 35 ft-lbs and plugs to 15 ft-lbs. Installed passenger warning placard. Traced inop wire to alternator field and terminal 4 of the voltage regulator. Repaired the wire with a Molex connector. Installed both N numbers. Taxi test, all systems nominal. Main alternator working!!
