Brief Description: Made additional brace for F12-13 edge clearance pr
Made two plates out of .063" to add to the F12-13's that have edge clearance problems on one of the two AN3 bolt holes that join it to the W17-06 main spar bracket. Probably not necessary but this is a critical area and just wanted some additional piece of mind.
Also cleaned some powder coating off the flap control rod so it will fit in the Delrin blocks.
