Brief Description: Continue fitting front fuselage components
Continue fitting front fuselage components, completed all 4 motor mount angle assemblies so they fit within each other and the fuselage stringers. Updrilled to #30 all floor angle components to skin. Fitted and drilled the third F08-09 used for the rear of the landing gear support. Also drilled the landing gear stiffener angle to the F08-09. Have deburred some of the floor angle pieces but have more to do. Also need to remove the bottom skin and deburr. I think I will remove the side skins so I will have room to properly drill the F08-09 angles to the side angles F12-03,04 & 05, left & right. Also need to updrill the engine mount assemblies for AN3 / AN525 hardware.
