Mounted two static ports in the fuselage sides and routed the tubes from the ports to the location where my DYNON SkyView AHRS module will be mounted. I used two machined static ports from Cleaveland Tool in Boone, real nice parts and they are 100% compatible with the 1/4" plastic air fittings that are popular for experimental aircraft. The ports require 1/2" holes and are glued into place using Proseal.
Inside fuselage ports held in place while Proseal sets
