Brief Description: Updrilled and debured rear center spar and compone
Updrilled and debured rear center spar and components. I only drilled the holes as marked on drawing W15, the others will be drilled when fitting the ribs and fitting to the fuselage.Had to trim about 1/16" off the outer edge of both W15-02's to allow end rib tail to fit.
When I got home I decided to cut the (6) 2 by 3/16" angles needed for the wing lock brackets. Next process will be to further shap the brackets.
