Brief Description: Drilled right rear spar ribs 6 & 7 to main spar
Also ground out the short aileron rod pass through the main spar. Riveted the backer plate and rib attach angle to the rear spar. Rib 6 & 7 have been fitted and drilled to main spar. Have 4 more outer ribs and spacers to drill and then I will assemble the right wing structure.
