Worked on folding area: Up drilled all the trailing ribs of the folding joint and all the attach angles. Countersunk all the trailing ribs backer plates. Sorted and clicoed all other ribs and attach brackets. Polished the wing release lever and will engine turn the folding area wing backer ribs tomorrow. Engine turning is tedious so I probably wont get anything else done tomorrow. Once the parts are engine turned I will rivet all the ribs.
Note: I noticed the 12 MS24693-S32 machine screws used on the bearing blocks are not long enough so will order some MS24693-S34 screws from ACS.
