Riveted VS skin to structure including the VS rudder hinge half and the fiberglass tip. Left out rivets on rear lower spar as specified by instructions. Will need to do a little body filler work on the tip leading edge before painting. Will wait until I'm finished with the HS so I can do all three tips at the same time.
