Worked on Rudder; cut and drilled skin. Still waiting on 4 BO'ed ribs needed for Rudder and Evelator completion. Also have one malformed elevator root rib, not sure if I can use it, will depend on the rivet edge clearance near the tail of the rib which I have yet to determine. Am having problems identifying and locating the control surface ribs in the kit. Seems the part numbers on the drawings do not always agree with the part numbers on the components. The component part numbers do agree with the packing content lists.
