Joe's OneX #129 Project
Date:  8-29-2014
Number of Hours:  3.50
Brief Description:  Finish fitting the rebuilt cross tie.
Finished fitting the cross tie that I had to modify extensively. It now fits perfectly, the rear spar holes line up with the cross tie flange holes, the part fits flush against the vertical channels and the bottom holes line up with the bottom skin holes. The bottom flange is flush with the bottom skin and the rear spar is at the proper height so the #1 ribs flange line up with the rear spar so the wing skin will transition smoothly from the rib flange to the rear spar. I've probably spent over 20 hours screwing with this part and am happy to finally get it completed and have it fit properly.
