Brief Description: Riveted right #1 rib to fuselage side
Also set the main spar into the fuselage and installed the seat sling so I could sit in the airplane and measure for the rudder pedal placement. Once determined the location I removed and drilled the pedal mounting blocks to the side and center angles. Was surprised how far rearward the pedals ended up although I do have a fairly short inseam. The seat sling is not very comfortable, strange seating position with knees way above my butt, will probably need a lot of padding.
