Brief Description: Drilled rib mounting hardware to spar
Drilled rib mounting hardware to spar. Completed ribs 2 - 4 on both left and right sides. Have the right root rib hardware left to match drill to the spar. Will next rivet the rib doubler gussets to the ribs, it is easier fitting the gussets to the spar before riveting them to the ribs.
