Joe's OneX #129 Project
Date:  7-29-2014
Number of Hours:  1.00
Brief Description:  Made additional brace for F12-13 edge clearance pr
Made two plates out of .063" to add to the F12-13's that have edge clearance problems on one of the two AN3 bolt holes that join it to the W17-06 main spar bracket. Probably not necessary but this is a critical area and just wanted some additional piece of mind.
Also cleaned some powder coating off the flap control rod so it will fit in the Delrin blocks.
Added plate to reinforce F12-13
Flap handle rod with powder coating removed
