Brief Description: More work on panel & rudder pedals
Got home from the hangar early so worked a bit longer in the garage.
Countersunk new instrument panel rivet holes and also cleaned the powder coating off the rudder pedal weldments. I know John Monnett has an EAA tip video where he uses a torch to remove the coating but I prefer to use an abrasive. After removing the powder coating you still need to grind the weldment down a bit before it will fit into the end blocks. I used a bench top combination disk and belt sander to remove the coating which worked well.
