Brief Description: Updrilled holes connecting front and rear fuselage
Up drilled fuselage holes that connect front and rear fuselage sections. Updrilled to #30 all holes and then up drilled to 11/64 and reamed to 3/16 the holes for the AN3 hardware. Also countersunk the 4 AN3 holes in the top stringers per plans.
Probably next step will be to remove the right front fuselage skin and fit the NACA air vent.
