Brief Description: More drilling & deburring on forward fuselage
Drilled to #30 the bottom skin to the frames. Also drilled and reamed for AN3 hardware the side frames and bottom cross members. I removed the parts and clamped them to my table for drilling and reaming since there was not room to do it while assembled. Was carefull to keep the parts aligned, perpendicular to each other and the drill vertical when drilling and reaming. Disassembled and deburred all parts then reassembled.
Tomorrow I will updrill the firewall to the front of the frame and updrill and ream the motor mount assemblies for AN3 hardware.
