Brief Description: Deburred turtledeck skin and formers
Spent a lot of time deburing all parts associated with the turtledeck. Turtledeck is now ready to be riveted HOWEVER, I plan to wait a while until riveting is absolutely necessary. I don't want to paint myself into a corner creating a situation that I can't get to some key part or location or make it very difficult to install some pieces at a later date. Seems the best rule is to always put off riveting as long as possible.
Next I plan to start work on the fuselage midsection. I think once I get the midsection drilled and ready to rivet to the end section of thefuselage, I will then rivet the turtledeck. I'll leave the rear fuselage bottom off just in case I need to get at something later. Probably wont rivet the bottom skin on until just before painting.
