Brief Description: Worked on F21 fuselage side parts
Cut inspection holes & rudder cable slots in side panels. Adjusted bends in side skin ends to 8 degrees. Chamfered edges of splice plates and marked for bending.
Note: The inspection holes are in different locations on the left and right skins, same for the rudder cable slots. The side skin drawings on F21 that locate the inspection holes are viewing the sides from the inside and the F01 drawing that locates the rudder cable slots are views from the outside, can be confusing. I think it may be less confusing if the views on F21 were also from the outside of the skins, just my opinion.
