Brief Description: Finished left OB wing structure
Finished left OB wing structure: Riveted in the bearing block brace to second rib making sure the rib spacing was correct and the top flange of the brack was parallel to the spar and level with the rib flanges. Also assembled the short aileron rod and attached to the bellcrank. Need to match drill 3/32" the aileron hing to the spar and mount the aileron to check for push rod clearance through the spar hole. Looks like the push rod is pretty close to the bottom of the spar hole, not sure about the side to side clearance. Will find out when I test mount the aileron.
