Joe's OneX #129 Project
Date:  8-16-2013
Number of Hours:  3.50
Brief Description:  Continue work on wing folding area
Continue work on wing folding area: Finished riveting all 4 ribs to backer ribs. Also riveted the paddle arms and the 4 spars to the angle brackets. Drilled one angle bracket and spar to a bearing block, have 3 more to do.
Received the two replacement paddle bearings from McMaster - Carr. Pounded out the old bearings with the broken flanges. Tried heating the block to free up the bearings but that did not work. Then just used a small punch to punch out the bearing dust cover and then the bearing balls and the collar. I then was able to drop a small socket into the hole and easily pound out one of the bearing. I then used the socket again from the other side to pound out the bearing I had removed the guts from.I cleaned up the block bore with a small grinder and emery cloth and then pressed the new bearings into place using an arbor press.
Right inside rib
Right inside rib
Left ribs
Left ribs
right outside rib
right outside rib
