Joe's OneX #129 Project
Date:  5-27-2013
Number of Hours:  0.00
Brief Description:  2 - Panel Layout with Dynon Avionics
Current Panel Layout using Dynon Avionics: This is a day VFR panel using Dynon SkyView EFIS, radio and intercom. Considered MGL but feel more comfortable with Dynon product since that is what I have in my RV9-A. Design and layout will probably change over time. Kind of hard to justify the expense of the Dynon panel in an airplane of this type.
I'm considering a Greatplains VW engine with a standard carb in which case I will probably need carb heat and a fuel boost pump.I'm trying to lay out the panel according to how it will be used during flight and by which hand, left or right.
Panel Using Dynon Products
