37-05 Bent arm of T-1209 Fuel Res Sender to match template Temporarily mounted to T-1209 sender plate and mounted sender plate on fuel tank assembly Checked float arm for correct height in high and low positions
Cleaned pro-seal off tank
37-06 Match drilled T-1204B fuel filler flange to tank top Final drilled tank top for mechanical fuel gauge
Rearranged hanger in order to bring tailcone down from loft
