11-08 Riveted pitch trim pushrod to clevis plates Riveted threaded insert to pushrod Installed rod end bearing in pushrod Installed pitch trim servo to pushrod assembly
Installed pitch trim servo tray onto brackets on aft tailcone bulkhead Attached pitch servo assembly rod end to AST assembly
Tested pitch trim servo at both ends of travel for proper clearances as called out
Pitch trim servo assembly
Pitch trim servo assembly attached to AST assembly
