Jim's RV-12 Web Site
Date:  2-7-2015
Number of Hours:  5.00
Manual Reference:  37-05 & 06
Brief Description:  Fuel Tank
37-05
Bent arm of T-1209 Fuel Res Sender to match template
Temporarily mounted to T-1209 sender plate and mounted sender plate on fuel tank assembly
Checked float arm for correct height in high and low positions
Cleaned pro-seal off tank
37-06
Match drilled T-1204B fuel filler flange to tank top
Final drilled tank top for mechanical fuel gauge
Rearranged hanger in order to bring tailcone down from loft
Fuel tank Res Sender arm
