Jim's RV-12 Web Site
RV-12
31B-06 to10
Fuselage wiring harness
31B-06
Inserted Molex pins into Molex plug & connected to plug coming from Dynon FT-60 fuel flow transducer
31B-07
Installed WH-0056 Aux Music Jack into F-1203A bulkhead & inserted wires into Molex connector
Inserted Aux 1 Music wires from wiring harness into Molex receptacle and plugged into Aux Music Jack connector
312B-08
Routed stall warning wire & inserted into ES-00077 floating connector (female)
Installed gnd wires & attached to L & R floating pin connectors
31B-09 Inserted autopilot pitch servo wires & gnd wires in ES-001 Molex plug
31B-10
Routed spar pin wire thru wire run conduit
RV-12 Home
967
205
209
Flaperons
306
Lighting Kit
