Jim's RV-12 Web Site
RV-12
31B-03 & 05
Avionics cooling fan & wiring routing
31B-03
Routed the Com, Transducer, & ADS-B antenna cables as called out
Routed the ELT phone cable as called out
Inserted the snap bushing into F-1204 center section assembly
31B-05
Installed connectors on the ES CPU fans
Installed the ES CPU fans
Ran wiring harness thru snap bushings in F-1202B panel base
Avionics cooling fan and antenna wires
RV-12 Home
967
205
209
Flaperons
306
Lighting Kit
