Jim's RV-12 Web Site
RV-12
29A-05 & 26-02
Instrument panel base & seatbacks
29A-05
Clecoed F-1202B panel base to F-1201A upper firewall & match drilled longeron
Clecoed canopy ribs to panel base & match drilled the F-1202Y strut attach angles
Final drilled engine mount brackets & riveted to panel base
Inserted 2 snap bushings as called out
26-02
Prepped F-1237C L & R seatback angles
Prepped F-1237B & D seatback angles
Prepped 1237G seatback braces
Fabricated F-1237H seatback hinges & drilled #30 locating hole
Fabricated F-1237 fwd & aft seatback brace hinges & drilled #30 locating hole
Match drilled #30 holes from the F-1237G seatback brace into F-1237 aft seatback hinge
Match drilled #30 holes from F-1237D lower seatback angle into the F-1237H seatback hinge
Fabricated
Match drilling longerons
Seatback parts
RV-12 Home
967
205
209
Flaperons
306
Lighting Kit
