Match drilled F-1251 nutplate brackets to step attach angles & F-1202F bulkhead
Primed step attach angles
Riveted nutplates to F-1202F bulkhead & installed bushings as called out
Prepped F-1213 left & right seat floors Dimpled & installed nutplates as called out
Prepped F-1207Bbaggage bulkhead, dimpled & riveted nutplates as called out
Prepped F-1286A left & right auto pilot servo brackets & left & right servo angles Riveted servo brackets & F-1207B baggage bulkhead to baggage ribs Riveted servo angles to servo brackets
Prepped facet pump bracket, clecoed to bottom skin and match drilled Countersunk for nutpltes and riveted as called out Riveted pump bracket to bottom skin
