Assembled V-groove jig to hold elevator.Purchased 8' 2"X8" and door hinges from RP lumber for bender.Bent trailing edge.Mounted skin in jjg and drilled the skeleton ribs and spar.Aligned and drilled the E-613 counterbalance skin.Debur, dimple and primed.RTV stiffners at trailing edge.Rivet..................................... with Deb's help.
