Brief Description: Drilling the Horizontal Stabilizer
Completed the right horizontal stabilizer in the Drilling the Horizontal Stabilizer section. Just like the left side, but took much less time. This included clecoing the HS-702 front spar, HS-603PP rear spar, HS-706 tip rib, HS-708 and HS-405 main ribs, HS-404 and HS-707 nose ribs, and HS-710 and HS-714 reinforcement bars. Next cam clecoing on the skin and match drilling the skin to the ribs. Finally, the skin was removed to allow the outboard holes on HS-710 and HS-714 to be drilled.
