Brief Description: Cleaning the tanks & preparing the area to add pro
My social life reduce my availble time to build. But we cannot do everything and a balanced activities is healthy for the couple & for the construction ! So this is the reason why I only had 4 hours available this weekend !
So I decided to clean the proseal excess that had stained the surface and also I noticed the fit between the LE and the tank LE was tight due to some proseal in the way. So I cleaned out everything and made a discovery on both fuel tank : each had a missing river holding the skin and the rear baffle. What suprises me is, I never saw it depite being careful ! The holes were filled with pro-seal and there was no leak in there ! So I cleaned out the 2 holes and prepared it for adding a rivet when I'll do the proseal around the cover.
Lesson learned : double & triple checkeverything. They are difficult to see and a tiny distraction and you miss it !
