Jean RV6 Construction Log
Date:  11-18-2017
Number of Hours:  3.00
Brief Description:  Cut out bottom flange on rib station 73,5
Did not have much time today. But I manage to complete a few errands. Finished pilot drilling 1 leading edge rib on the right wing ; sorry no picture of that.
Also because my kit is an old version, the access plate at the bellcrank is not pre-formed in the sking; I have to make a ring to support the access plate and because of it, I had to cut out the bottom flange on the same rib as the belcrank support and add a small 2" angle to reinforce the area. This is what you see here.
