Jean RV6 Construction Log
Date:  5-25-2024
Number of Hours:  1.00
Brief Description:  Sanding
This morning I had a little bit of time to work on my cowling. I mostly sanded it , check the clearance and checked the solidity of the modification. I am happy with the result and that is an other item done and checked !
Also, I think I came to the conclusion that I won't get the RV6 in the air this summer because I have number of other projects that takes priority. Although I pushed to complete it , I am running out of time and the only possibility remaining is to push the first flight to next spring ...
I never thought to have to come to this decision once retired, but sometimes priority is what matters. When I started this project I promised myself that I wouldn't cut corner and my decision has a lot to do with this ... Now it is almost ready to fly but I will have to wait a bit longer before going further.
It will be just better.
Perfect clearance  !
Perfect clearance !
After first sanding round
Side view of that modification
