Jean RV6 Construction Log
Date: 8-8-2021
Number of Hours: 3.00
Brief Description: Storage of the wings
Space ! There is never enough space. At any rate, if you read my previous spot, you will understand why I sorted them on the ceiling of my garage. But it's one thing to have the space to put them up there, but sometime you need to reposition other things .
In my case, I have to reportion my garage lighting, re-route the wiring, re-position my compressor hose reel (it's an auto-retractable one that was in the middle of the ceiling) because it was iterfering with the spar.
To insure that no problem would happen, I installed each wing on straps on hooks screwed to the wood unde the Gyprock. As a safety measure, I added 4 additionals hook and 2 stronger straps pass under the bottom wing should something gets loose and fall down. Finally I have added some towels in between to prevent any contact should the top one drop on the bottome one.
Finally, there was enough space to put the horizontal stabilizer on top of the wing closer to the ceiling.
Now, my wings are well and will stay there until next summer !
End view
Side view
