Jean RV6 Construction Log
Date:  4-5-2021
Number of Hours:  21.00
Brief Description:  Electric flaps system & manual aileron trim
It definitely goes slower. Installing equipment takes much more time than I anticipated.
But overall I've made progress and I am please with it. Essentially the electric flaps system is ready and could be install when needed. Because of the floor angle, I elected to modify the front end side panels by cutting them to permit to follow the floor. As you can see, I added a small doubler to hold the floor shape. That will not be seen as the seat will be thicker than the double you see on this picture.
The aileron trim was a little challenging because I had drilled the holes for the floor but it was interferring with the plate holding the device.
Electric flaps view assembled
Flap side panel modified
Manual aileron trim
Manual aileron trim
