JEAN'S WEB SITE
Date:  4-25-2020
Number of Hours:  6.00
Brief Description:  F-606
Since I upgraded to W10, pictures turned side ways by themself. I tried to change them but it seems to be impossible. I think pictures can only be taken in landscape format. I will try to retake appropriate pictures and repost later.
F606 is not a simple one to assemble. F687 the one on top, there is an issue if you follow the instructions ... If you drilled holes in the center to attach the two F606 sides together, it will interfere with the vertical web of F687 ... I will show you a picture later on this.
The main issue is it is so flimzy, it wobles whenyou try to line up something.
Wood added to give some rigidity
