Jean RV6 Construction Log
Date:  10-2-2019
Number of Hours:  1.00
Brief Description:  Checking tank leaks
Finally got around to check leaks in the fuel tanks. The right tank was perfect and had no leak. The left tank had a small leak around the cover through the gasket.... of all the possible leak place that is the easiest to fix !
I do not plan to take the cover off but instead simply add proseal around the cover edge.
1 PSI & soapy water !
The leaky one !!
The leaky one !!
