JEAN'S WEB SITE
Date:  7-28-2019
Number of Hours:  1.00
Brief Description:  HS final riveting started
I tried to cope with the heat but had to stop after only riveting 15 rivets in the mid rib on the bottom side. The humidity level was so high, I quit !
Something odd happenned also today: Check my little weather station. Not sure I saw that before. Check the dew point --- middle picture, left of the clouds graphics. It is 2 degree above the temperature and the humidity is only at 54%.
I read and here is the wiki answer: If the temperature is below the dew point, the vapor is called supersaturated. This can happen if there are not enough particles in the air to act as condensation nuclei. Interesting hey ?
UPDATE: I found out that it change from Dew Point to Heat Index when the temperature exceed 27 C ! I thought that it could not be saturated if the humidity level was at 54%. It did not made sense ! So that 32 was the feeling we had when the temperature was at 30 ! Later that day when the temperature dropped to 25 C the Dew Point reappeared and was at 19 C which makes sense !
HS after riveting HS607 rib bottom side.
Dew point higher than the temp ??
Dew point returned to normal later on ...
