Jean RV6 Construction Log
Date:  6-24-2019
Number of Hours:  4.00
Brief Description:  VS & Rudder
I did not have much time but managed to rivet final the VS et worked on the rudder bottom fiberglass bottom end. As you can see, I wanted it to be removable so I cut it in a way that permits to remove the end and slide out the fiberglass. I also drilled the holes at the end for the white tail light.
VS completely riveted
