Jean RV6 Construction Log
Date:  3-10-2019
Number of Hours:  8.00
Brief Description:  Changing wing position on jig & drilling bottom ou
Yesterday Yvon came and helped me swithching my wings so I could have access of the bottom. After that I cleaned out and re-organised once again !
Today I drilled out the bottom outbard skin of the left wing. I installed the pitot mast and made the access panel that goes under the bellcrank. I installed the access panel the old fashion . I did buy a jigger tool but simply cannot jig anything. I search to see how to use it and could not find anything for that tool. I abandonned and went they old way despite that it adds a little bit of weight.
I marked up the skin and was surprise that it was exactly as per the plan. Than means all ribs are in the same exact position as per the plan ! I was please with that !
Marked & drilled skin
Pitot mast hole drilled out.
Access hole
Access hole
