Jean RV6 Construction Log
Date:  3-3-2019
Number of Hours:  12.00
Brief Description:  Debur, dimble & prime
Not much to say ... As you can see , I am using a drill to debur. I set pressure at 20 psi and hit the trigger for a fraction of a seconde and the tool makes 2-3 turn almost with no pressure on. It works quite well.
The toxic primer force me to use an external air supply as well as using my wookworking cyclone to exhaust the fumes. Despite all the precautions, it does sneak in the house.
The 12 hours is spread over the weekend . I am ready to start riveting it together. Probably Wednesday as I am taking a day off.
