JEAN'S WEB SITE
Date:  2-11-2018
Number of Hours:  6.00
Brief Description:  Drilling top outboard skin on LW
It went better than I thought. This time I first marked the center of the main ribs, then put a transparant plastic sheet over the ribs, traced the center of the ribs on to. Then took those transparent sheets and put them over the skin and using the drilled stips as a guide over the traced line, I drilled the skin. Then I went on the wing and drilled the ribs using the skin as a guide.
Used a drilled strip to drill skin first
View of the cleco skin on LW (RW in back ground)
Inside LW
Inside LW
