JEAN'S WEB SITE
Date:  1-21-2018
Number of Hours:  7.00
Brief Description:  Preparing LW
Seems I have done little today. I finish drilled the ribs, drilled the hole for the tie down ring on the right wing , debur and cleaned with MEK all the rib. My goal is to prime everything I can on the left wing and do touch up when required.
View of LW spar drilled to size
Tie down hole on RW
Tie down hole on RW
Drilled, debur and clean ribs
