Jean RV6 Construction Log
Date:  1-7-2018
Brief Description:  Re-drill LE skin replacing the first one that had
So to save efforts, I cut the faultive LE sking to use it as a drill guide. The green tape are the holes I did not drilled because they were incorrect. I then reinstalled it and will wait for the replacement skin and the now first LE rib to arrive to complete. But it fitted as well as the first skin !
cut LE skin & marking direction clearly
green = do not drill
LE reinstalled
LE reinstalled
