JEAN'S WEB SITE
Date:  9-9-2017
Number of Hours:  3.00
Manual Reference:  dwg 3a
Brief Description:  Installing fiberglass tip on HS
I have decided to use #6 screws to secure the fiberglass tip instead of using pop rivets. I still need to close off the ends but I need to have the elevators attached to adjust the gap correctly.
My HS is now complete until I can finish it up after inspection that should happen in, hopefully before next spring !
