Jan Hanekoms RV Web Site
Date:  2-5-2015
Number of Hours:  5.00
Manual Reference:  8
Brief Description:  Tip Up Cabin Frame
Measure out F631A frames as per instructions in plans.
Cut two 1.5 inch holes in the two rear frames.
Clamp the rear frames and measure width and height and trim to adjust.
Drill and cleco the F-631 plate.
Prepare F-631B strips and chamfer edges.
Clamp structure to a flat surface and drill and clecoe the F-631A rear frames to the F-631B strips.
Rear frame hole
Rear frame hole
Rear frames drilled and clecoed
