Prepare front and rear spars as per instructions. Clecoand drill hinge brackets as pre plans. Trim spar caps as per instructions. Clamp and drill rear spar caps as per instructions. Cleco and drill HS-906 Rear Spar doubler as per plans. Rivet VA-146 bearing to brackets as per plans.
